caliper advice needed
Vancouver, BC
this is for my 92 pickup, but i'm sure could be applied to the fj40 as well, and since no one really reads the toyota truck tech section...
on both of my front calipers , the inside pad has worn down to zero percent while the outside pad has 60-70% left. i got a price from the local parts place and got a very good cost of $58 ea + core, but i would rather repair my calipers if possible. i was talking to a guy that knows much more about mechanics than I and he said it is very common for rusty pins to cause this problem and that if i just remove the surface rust on pins, i might be ok. just looking for some advice from someone else who has hopefully been there, done that. thanks
hey SizzleChest check the local parts place for a special lube for the pins. i dont remember the name brand but its a company that makes alot of brake related stuff. any way you coat the pins and it helps them slide and the stuff doesnt break down and lasts a long time. our mechanics at work use it on our rigs. i think it may be a CRC product, not sure.
my old ford F250 had the same problem and it ate threw the back of a rotor when it froze up.
The uneven wear being caused by rusty/sticking/ gunked up pins is a problem in floating calipers. I've never seen the effect from the problem in fixed calipers (Toy trucks and Cruisers use fixed calipers).
Mark...
Sounds more like the pistons on the outside of the rotors are not moving. You can check this with a helper. Pull the wheels and have your helper push and release the brake pedal. You push the pads back with a pry bar or screw driver. Have the helper push the pedal again while you watch for each of the 4 pistons to push the pads against the rotor.
The only pins in the Toyota system are the ones that hold the pads in the caliper. I can see that maybe they might hold the pad cocked and wear them wedge shaped maybe but not likely.
Me? I'd buy and install the new calipers and get on to doing something else.
Nick
