Ca VS Or Smog
Santa Rosa, CA
hey is any one a smog expert? will an oregon 80 pass Ca smog? does oregon even have smog? do i need to move? (actually that last one may be in the card in the not to near not to distant future)
well the one thats on the front of the burner that im really tempted to jump on is a 91 but all the fj80's in gereral.
and yeah if i can't find one in cali then i supose oregon or arizona would be thr next best thing other wise i gotta fly somewhere or rent a tow dolly and pull wifeys car back a long ways.
Most of Oregon has no emissions testing. So for most of the state, you'd have no idea (same as buying from much of the US) whether the vehicle had been maintained in such a way that it would pass CA smog requirements.
The two regions that DO have testing are Portland, and the Rogue Valley (Ashland/Medford area, just north of CA on I-5). In those areas you could ask the seller to get a volunteer inspection (it's a surprisingly convenient and free drive-thru process) and communicate to you the results. This would give you the actual HC, NOX, etc. numbers at idle and at 2500rpm (not on a dyno though, just revving the engine). Then you could compare that to the allowable levels in Kali. to see whether you'd be likely to pass.
Curtis
Thanks curtis that helps quite a bit
nother question is one better than the other (lx450 or 80) or is it all just lux options on the same truck?
My guess is that if you were going to purchase an out of state vehicle to import into Calif., you'd first go to a Calif. referee station, explain the out of state vehicle, and ask what the trauma is going to be. The ref will already know how the out of state vehicle is equipped.
They can all come in and '91-2 have a federal and Cali computers. I have both and there are two different ecu numbers. There are different standards for both although I cannot see any difference in the harness or smog devices.
i haven't had so much luck with the ref the local one kinda seems a little daft to me
