C0210 and C1223 Codes after lifting for an oil change
You stretch the wire during install. Common mistake. Need to find the break and splice it or replace the whole sensor.
I did not word that correctly..I put it on a lift to change oil. It has had a lift installed for over a year now. But I do think I created a break somewhere.
Do you have long travel rear suspension? I think the bracket need to be lowered in that application.
If it's standard travel it should not stretch it more than stock.
Took me awhile to get it back up but it was pretty quick finding the issue. RS speed sensor pigtail is fubar. It’s part of a sub harness that plugs in above the axle.
Wow. Someone did a “repair” of both ABS/Speed sensor pigtails at one time. Surprised it’s lasted as long as it has.
