Bypass window switch on a '94
MDarius
I break stuff.
Bountiful, UT
Does anybody know how to bypass the window switch for the DS front window on a '94? My switch is bad (pretty sure) and my window is stuck down about an inch. It is supposed to rain/snow here this evening and I'd like to not resort to duct tape and saran wrap to keep the wet out.
Thanks!
I was having similar window issues with my 94 as well. I ended up taking the driver and one of the passenger switches apart and then cleaned all the contacts in them and now they work fine. This is a somewhat common issue I think. It didn't take that long and is a fairly straightforward procedure. You might want to give that a try.
Yah, I pulled it apart last night. The "Window Lock" button came apart and I fiddled with it for a couple hours trying to get it to go back in to it's slot. I ended up bending the little spring. Just when one part would sit nicely, another would fly out the other side. I did eventually get it all back together, plugged it in, and still no worky. I'm pretty sure something is fried, either on the board or in the switch. When I depress the button nothing happens, and when it killed it just quit working, no warning from the motor, so I don't think it's the typical dry guides, etc.
There are 2 contacts for this switch. they looked OK, but I cleaned them anyways. A lot of frustration for no results.
Any other ideas?
Just pull the switch panel from another window and use it to roll up the window that's down. My rear windows won't go back up (bad switches), so I leave them unplugged at the door. If I do need to use them, I pull the switch panel off my pass front door and plug in the switch. HTH
Thanks. I'll have a look at the other switch plugs. I'm guessing they'll be different since the drivers door has all 4 windows, a master door lock, and a window lockout, but I'll take a look.
Duh! I pulled the switch from my '95 and tried it. The window still doesn't go up, and all the others worked, so it's not the switch after all. I'll go surf the stuck windows threads for a while longer. Thanks!
