buzzing relay
I have found threads concerning the buzzing relays but found nothing on which relay controls the cdl. My buzzing stops when I shift into four wheel low. Another issue is that my abs and cdl light continuously flicker. Any help would be appreciated.
Edit-*I thought the date was January of this year for some reason, my guess is that you probably got it figured out after 4 years? Whoops, my bad!*
The CDL control relay is under the left kick panel. Search the “Slee 7 pin mod” (or something like that) and it will walk you in to the relay. I did remove the mounts for the ABS control relay (the shiny silver box above the left kick panel) for much easier access to the relay and the connector. My problem is that when my CDL switch is in off position, the CDL control relay is actuating on and off pretty rapidly (almost buzzing)-when I actuated the switch to the on position (even with a blown fuse and before AND AFTER the 7 pin mod) the “buzzing” would quit. Still troubleshooting it. If I come up with something I’ll let ya know what was causing my issue. Maybe it’ll help you out!
