Busted Antenna, How Bad?
One other benefit to going to whip or rubber, it frees up a switch spot on your dash!
It takes about 10 minutes to swap out the whip and mast. You don't have to pull the fender liner or anything. The antenna/motor will fit through the hole in the engine bay and you can do all the work right there. The antenna wire seems to be permanently attached or something though?
Posting this on a couple threads.
The motor can be fully removed without removing the antenna cable to the radio by following the steps you'll find and bringing the motor through the hole into the engine bay. However at that point if you remove the screw just below where the antenna shafts meets the motor housing the shafts along with the attached cable can be separated and left in the engine bay. I was able to clean the brushes, not lose all the small parts and get everything back together on a bench which would of been about impossible.
