Bushings and Tierods
Virginia Beach
All the rubber pieces underneath. Who has replaced them all? What did you notice when you did? Did you go OEM or aftermarket? What is the best kit/deal you know of?
Reason I'm looking into doing this is because I'm getting cupping on the tires. Read up on this and all articles are suspension based or alignment. Since I have been told that the lc won't align properly and that cupping could be suspension based.
I have the OME 3" with J springs since 2006 and slee caster plates.
I got the complete tie rod set from a guy on here for $162. Haven't received them yet but they are oem and probably a little over $100 off of stealership prices. I'll let you know when they go on how they are. I need to do the bushings on mine also before I lift. I just got my rig so trying to no replicate the death wobble of past jeeps. Don't ever wanna feel my entire front end threatening to explode at 57 mph down a busy freeway. He is on here as ranma21
By the way I might have to come and check out your rig. I want to go the j/heavy/L route with plates. Drive ok other than the worn out bushings?
