Burping the coolant system
I reinstalled my heater a couple weeks ago and have since been bothered by wierd heat issues. I've heard of the need to burp the air out of the line. I parked with the radiator cap higher than the hose that goes over the engine, ran the engine for several minutes with the cap off. Fluid levels occasionally would raise and fall, not big air bubles spotted. Replaced cap and thought I was done. Cruiser will run OK then suddenly the temp gauge raises high, usually when there is no reason in the world for it to get hot. Short distance driving in cool weather. I can't see why it would heat up other than an air bubble or something.
So,
What more can I do? Power flush the system? Is there any other possible explanations for the sudden heat issues since reinstalling heater? Mind you at the same time I installed SM465, New Marine switch for dual batteries, so more than just the one variable, but can't imagine they are related to the heat issue. Oh, and when I get out and check, it really isn't that hot. I don't think it is a true temperature reading. Is the guage going bad?
Trying to get ready for Cruise Moab!
thanks for any help
troy
did you have the heater(s) on when you burped it?
Install a new radiator cap....
What are you using for an overflow tank?
When was the last time you replaced the thermostat?
I did have the heater on/ valve to allow water to the heater on.
Radiator cap is fairly new but cheap and may be worth replacing
Thermostat replaced 2 years ago. Over flow tank is nice plastic bottle that has worked well in the past. It has the right amount of fluid in it and vented properly.
Thanks for any suggestions so far. I'll get a new cap, may be worth a new radiator cap. I drive an F engine. I'm not supposed to have heating issue!
troy
