burning oil "?"
Cleveland. Ohio
i've just noiticed a weird problem with my truck. It looks like it's burning oil. but it's only hapenning after a long drive (150-200 miles) Last time i drove it for about 200 miles, and had to add 1qt to get the level back to normal. And the oil level stays normal on regular day to day drive. What can be wrong??????:mad:
sorry for my poor english:rolleyes:
I have the exact opposite problem. I burn 1.5-2 quarts per month, mainly in town driving back and forth to work (15 minute trips) about 1500k per month. It's been this way for years. I probably should switch to the Rotella, but it's made it this far on everything else I've put in.
I drove on 2-500+ mile trips this summer, 1 towing a 2600# trailer and the oil usuage was barely noticeable. Same brand oil. I think things just get a little better seated in on the longer trips. Like after 160k things aren't seated in already.
The oil burning became noticeable a few years ago. I don't think it's a big deal. There is nothing coming from the pipe at startup. No cloud behind me during acceleration. It's just the nature of the beast. I scoped each cylinder when the oil burning became more noticeable a couple of years ago. There were no visible scars or scratches on the walls.
The local toyota dealer commented that there is a squeege like ring on the valve guides that usually is the problem. Personally I've taken a land cruiser engine apart. I'll just take his word for it.
My friend who is a diesel mechanic commented that at least you know you're getting some lube to upper part of the cylinders :)
My truck also 'needs' a bit of oil once a month but so far I thought that it's due to a slightly wet upper oil pan. Now I guess the problem might be different. On one hand I know that it shouldn't bother me to drop a bit of oil from time to time. But on the other hand I had a Nissan Pathfinder with 200K miles on the clock and I didn't have to add oil between changes. The Pathfinder has oil volume of 3.5 quarts. The Cruiser needs almost 8 quarts and still needs filling up (120K miles on the clock). This is what bothers me.
Your owner's manual addresses this issue --- look under "oil consumption" in the index. Basically short trips cause the oil to be diluted with fuel and moisture and makes the oil level appear stable. The fuel and moisture evaporates at highway speeds and makes it appear the oil is excessively consumed.
Oil burning is a hot-button issue with some people. When I was a mechanic, I got this question a lot, usually from someone who just started paying attention.
Engines burn oil. That is the nature of the beast. There is no way to avoid it. Piston rings must be lubed and some oil will always slip past.
Check your plugs. If one is not more fowled than the rest, and it runs well, don't stress. If yours burns more than mine does, you may have more oil ring wear for any of a number of reasons. Oil burning will not affect performance as long as it is even in all cylinders. Just top it up when needed.
I drove a 4-cyl Montero for ten years after putting a new engine in. It used the same amount of oil at 100,000 miles as it did when it was new. It has been said that if a Montero doesn't burn oil, you need to find out why it won't start! Mine used 2 quarts between changes. The new owner replaced the short and rebuilt the head. It still uses 2 quarts.
If the oil use is even in all cylinders, just feed the habit and drive smiling!
Wdf175, I have the same issues on a 94 & a 93 he! he! I just bought the 93. We just went to Orlando 3000 miles plus round trip and no oil usage at all, it was all perfect. I did check the oil everyday of the trip, it didn't needed anything at all. We came back and used the truck for about a week and it needed about 1/2 quart.
94 it's same thing. When driven around town, it needs oil at longer intervals then 93.
The 94 it's got ~133000 miles it's stock and the 93 ~153000 2.5 lift, front spacers & 285s
I read the manual and saw about the usage of oil. how can this issue be fix?
It seems like eliminating short trips may help.
My weekly trips and routes are consistent day by day, month by month, so I have plenty of benchmark info.
Therefore, I'm going to try the Rotella route on my next change and report if that helps the short-trip-oil consumption.
Tnaks for all the replies guys :cheers:
I think i've read every single post about oil consumption, and all of them states on burning oil,no matter how you drive it. I gues the question is : "What is the difference betwen engine running for a long time (2-3 hours),and short time(20-30 min) ?
Just trying to fix it,before i break something expencive, if there's anything to fix in this situation :grinpimp:
Just be grateful that you're not burning a quart every 80-100 miles, like I am.
I can't wait to get the new engine gone over, and into my rig. I feel like I'm the captain of the Exxon Valdez, every time I pull off the highway to put in more oil.
And, blame Woody's nag screen, for why I'm posting such an inane post... Gotta "engage in a conversation with another member in any one of our forums...".
I really can't wait to figure out what the hell the issue is with my truck. Personally, I've become convinced that it's the damn rings. I think I've hit everything else, although, lately, it's like the engine is leaking oil everywhere under the hood, too. <sigh>
alexander 24,
Refer back to MoJ's post of moisture/dillution for short trips. I think I can apply the information to my experience.
Alexander26 read post #2 & #7
I did exactly that. I change the oil a day before the trip to Orlando, FL. about ~1300 miles one way. I checked the oil level every day and no oil consumtion at all. We got back home and drove the truck for a week, my comute its about 10 miles per day, and it was missing 1/2 quart.
again, how can this be fix? what's the problem?
I would like to hear a solution for it.
I don't think that the engine needs to be rebuilt.
It certainly could be time for a PCV valve, or it could be a thermostat issue, it could be nothing. Oil is a consumable, you should have consumption from aeration and saturation of blowby gasses, moisture and hydrocarbons.
Solution for what would be my question? What's the problem? You go on a long trip, and your oil consumption is negligible. If there was a PROBLEM of oil consumption from an engine perspective, you would see it there. If you have oil consumption because of driving distances or habits, that's not necessarily something you fix with an engine repair.
Or to steal the obvious from one of the wittier on this list... Commute to Olando?:grinpimp:
Scott J
My engine had ring issues and was burning oil. I would lose copious amounts of oil on long trips at freeway speeds but lose very little driving around town. My oil consumption was extreme though. I would stop every hr and add a quart.
EricE--When you tore down the engine, what did the rings look like? Was it just the wiper rings, or did the compression rings sustain damage, as well?
I'm also curious as to what you think caused the issue with the rings. My suspicion is that the previous owner toasted the engine with a failed PHH, and that's why the rings failed. Did you buy your truck with this condition, as I did, or did something precipitate the damage after you bought it? Did you do your own work, or was it a dealer that put the long block in?
Thanks... I'm just gathering data. I've already got a wrecked '94 sitting up at my Mom's place that I'm going to do a quick overhaul on, and put the engine in my '93. Which will, I promise, be fully documented and then put together for the edification of the board.
Sorry, I won't be of much help. I inherited the condition from the PO. I bought it aware but ignorant of the extent and $ involved. I had the engine replaced with a crate engine from ATK (and have since had to do a HG on it due to improper installation of same). So I don't know the condition of the rings as the engine was never tore into. I always assumed it was due to glazing of the cylinders during the break-in of the original engine.
On my engine, the PHH was intact. I replaced it myself.
EricE--Interesting about the ATK headgasket issue. I don't feel so bad, buying a spare engine to rebuild myself, now. If you want something done right, I guess you have to do it yourself...
I hope that the collective Ih8mud hive mind will be able to conclusively help me diagnose the issue, once I get the old one torn down. I can't stand that I've had it to three different shops, and nobody can give me a diagnosis. One way, or the other, I *will* know what the heck is wrong with this engine, before January.
Thanks for the reply...
I have this issue of burning oil ONLY on long trips... in fact, I burn a quart per 100 miles... so that means I'm down 2 quarts by the time it's time to pull over for gas... "In town" I burn virtually no more oil than a typical vehicle.... but once i get on the open road... I have no idea where the oil is going...
I recently replaced the HG on this beast but I had not even taken a long trip prior to the HG so I have no reference point there.
I'm to the point that I'm extremely bummed out about this. I drove 4 hours this morning to my sisters and i just put my 4th quart of oil in for today... yeah, that extreme.... I took a trip last month with fresh oil and it still went low on me.
Could someone please explain what the owners manual means by that statement?
Can someone explain to me what the crap I need to be looking for?
