Burning ep80 diff oil smell help
Kent England
After a drive which dont have to be a long drive, 15 miles of more, when I get out the car I can smell the distinct smell of buring EP80 diff oil from around the rear right wheel, I have had a quick look under the car, but cant see anything wrong, has anyone else had this? or think what it may be.
Thanks
I notice the smell as well sometimes. The hub never feels hot, but the smell is hot gear lube.
Try touching the hub and feeling if it's warm, maybe due for a rear axle job? Bearings and seals?
That was the first thing I done, expecting the rear hub to be hot but it wasnt, about a year ago I took I was going to check the rear bearings, as soon as I started undoing the cap, diff oil started to come out, so I done the cap back up, I cant see any reason for the bearing to fail on the rears if running in diff oil?
I better check the diff oil level asap was 80k ago I last checked.
or am I wrong!!!
I have the noticed the same thing on mine. I had it looked at and the shop said it was the axle seals.
There is an inner and an outer. I got all 4 from the dealer for about $50, they are getting installed next weekend.
I noticed this smell when I first got my Cruiser, turned out that my front diff breather was oozing lube due to water ingested when I was playing in a stream. The oil was blowing onto my exhaust, hence the smell. I drained the diffs, repacked the burfields, put on a breather hose run to the firewall, and no more smell.
If the breather does collect a little oozing, it will travel up the breather and drip back down.
Jack Nichols, '93 LC
After i pulled the rear disks i could see where oil was leaking out from the inner oil seal (the inside of the hub). You can see how much more oil was in the right as opposed to the left.
So was it leaking out and getting onto the breaks and then burning?
Yes, burning inside the drum/parking brake. There is one rubber seal about an inch in diameter that goes inside the very end of the axle housing stub and another one that goes on the backside of the wheel hub that has a metal ring on it and a rubber gasket. It is about 3.5 inches in diameter. The seal on the hub also holds the inner bearing in place.
I just finished the hubs/bearings today. I am rebuilding my brake calipers tommorow and then will be able to test drive it and see if the smell is gone.
PS i should have taken a picture of the hub while it was off the truck but i didnt think to do so.
