Burned Coil Pack and Spark Plug (plug was good and tight)
outer space
Helping my buddy change his spark plugs and we came across this on the passenger side, 3rd cylinder in from the front (sorry I don’t know which one it is). Spark plugs probably have 90,000 on them and were OEM denso SK2OR11, replaced with same. A small amount of oil, and I mean maybe a drop was on the coil pack but it looked bad! All the others looked fine, with the exception of one plug have a small amount of burn on the porcelain and a browned tip on the coil pack but otherwise they all looked fine, with tan tips…
Edit: no misfire codes that I know of
Advice?
What should he be looking at? Replace it? And / or maybe valve cover gasket/plug seals???
'06LX470- my #3 looks just like this, coil has a crack up the seam as well.. I'm looking at my valve cover gasket leak as well... poured 1 1/2 bottle of AT-205 yesterday to help with the gasket..
I love that stuff, used it a lot in my steering rack but haven’t put it in the oil before for the valve cover gasket. I’ll research that.
With the appearance of oil being towards upper end of the boot seems this is more likely the spark plug tube seal that is responsible for this oil so replacing spark plug tube seals and valve cover gasket at the same time would be best idea. And checking/retorque valve cover bolts periodically over time to help keep those gaskets snug
Doing this^ and all new coils and plugs is my next big thing- Just seeing how the AT-205 holds up, so far still leaking.....
If you suspect the VCover-snug up the cover bolts, the gasket gets compressed so tightening the all that might help the leak(presumably if thats the case)
I should’ve done this! I’ll let him know, and check back in a few thousand. Does that coil pack need replacing now that the outer plastic is burned like that
It wouldn’t be bad idea to replace it but I wouldn’t replace with aftermarket version unless it actually failed and were stranded. I think there’s replacement boots available but I don’t have direct experience with replacing just the boots
The brown color on the shaft of the coil plug is oil residue. The oil intrusion in the spark/coil plug cylinder can come from two points, the spark plug thread area or spark plug round gasket in the valve cover. I would recommend to get your PCV replaced as well so crankcase pressure can vent.
1+1/2 bottle of at-205 seems like too much..
Usually I pour an oz or so on smaller systems, or 2 to 3oz on engines with 4-6qts of oil.
I think they recommend 1oz / qt of oil but that's also excessive considering that the at205 viscosity is similar to alcohol.
Be careful with the bolts, they're very fragile and can break easily, but I did tighten them up 3-4 years ago and no leaks since.
BTW I don't use at-205 on my LC, but got other cars I do, and a 1/4 turn on the VC bolts fixed the typical oil burning smell of leaky valve covers.
I use it on BMWs a lot.. 🤮
If seals around coils are leaking it won't help, a VC job is on the horizon, but try a new clean coil and check it within a few 1000 miles and see if it gets dirty..
I never use after market unless I have to, I’m teaching him the same. He’s been learning the hard way with a shop putting aftermarket Steering Rack in and it basically gets replaced under warranty every year. It’s terrible.
