Bundera turbs
G'day, I have an 86 turbo deisel bundera,or so ithought when I bought her. I was told the turbo blew and non turbo manifold was put on. So it acctually has the 2L non turbo deisel engine in it. I'm currently looking to put a turbo on it and need advise on any tested and successful turbo installs on the 2L block. Also any other useful info would be greatly appreciated.
Where are you located?
If you had a 2LT and the turbo was taken off, then you still have a 2LT... but without a turbo. The engines themselves are somewhat different - fuel pump set up, compression ratio
There are kits available, or you could take the parts from a 2LT or perhaps a 2LTE if the manifold configuration is correct for your exhaust port configuration.
~John
Cheers John, sorry I may not have been too clear. The motor has been replaced with a 2L motor rather than the 2LT. I have heard of people putting a garret T3 turbo from a Volvo on this motor but don't have much info.
