Bundera LJ70 injector pump problems
Tingha, NSW
Having injector pump problems, fuel can't get to injectors. Tried clearing out all hoses, had a bloke have a quick look at it and said that the fuel is going in the wrong direction. Had a look and can't see why, any help would be great, thanks
Hello! I'm having an issue with mine, it stalls after you reach 60 km/hr. Was this happening to you?
Did you fix the issue?
You could rig up a small container of fuel in the engine direct to your fuel pump. This will isolate the problem between the supply side and the fuel pump.
