bump stops
I'm not SOA but I set my bump stops by compressing my shock all the way (with the bottom loose) & measured to the shock pin, subtract the distance from pin to top of axle where it would contact stop (added 1" to this measurement) & set my stop at that height. That way at full stuff, I still have 1" before shock bottoms. This also allows for bumpstop compression. Hope this makes sense
My guess would be spring twisted too much do to flex. If one wheel is at full stuff & the other is at full droop on the same axle, that puts quite a bit of twist on a leaf spring.
Are you using a good quality poly bushing?
thats what my mate said today also... to much down flex ....... the red nolathane bushings i used my buddy said might be to hard and said to go back to the rubber ones and try that ...does that sound about right...and is nolathane the same as poly....
