Bump stops
El Paso TX
hey guys
so i installed bump stops on my 80. i have 315s on a 2.5in lift. i get rubbing at full articulation. (big suprise) so i have a question... is there an adverse effect with these things? all opinions welcome.:cheers:
What bumpstops did you install. You should have coil bumpstops all 4 corners and frame bump stops in the rear. So did you install frame bumpstops in the front? You won't get any adverse affects from bumpstops besides them contacting the area directly accross from them at full bottom out.
I have Nitto 315's on 3" OME lift. Everyone told me that I need rear stops. I have not had a problem yet.
Mine are heavies, so maybe they don't twist so much? I use then pretty hard sometimes. I learned from many years of desert buggy building that if it breaks, it was not good enough, and if it doesn't break, it was fine. Then I should leave it alone! Let it be!
i bought the rear bump stop extentions for the rear. they are located on the frame.
