Built FJ40 axles & tranny/t-case for sale
Roxboro, NC
FJ40 rear axle for sale. Set up for spring-over, 4.10 gearing, has disc brakes, stainless braided brake lines, and comes with spare axle shafts. $500
SM465 tranny mated to FJ40 t-case with aluminum adapter plate. Tranny has recent rebuild. Tranny has input collar to be mounted behind FJ40 straight 6 engine. Transfer case is twin sticked, has t-case saver installed, and has AA cross member. The 3-speed bellhousing is included to allow this unit to be mounted to a Cruiser engine. Will also include the .120" wall tube rear driveshaft from the set-up (is long enough for spring over with flipped rear springs). $700
FJ40 front axle. Axle is set up for spring over, knuckles have been cut/turned 16 deg, has armored removable front diff cover, 4.10 gearing with LockRight locker, 4340 cromo inner shafts and birfields, All-Pro spindle stud kit, minitruck knuckles, high steer, FJ60 calipers and rotors, Aisin hubs, U-bolts and plates included. Axle has been recently rebuilt. $1000
The rear axle and tranny/t-case are located in Roxboro, NC and the front axle is in Holly Springs, NC (near Raleigh).
R.K.
