Built bumper
Adventure Teq
Liberty Utah
Website
www.instagram.com
Finally got to it. 2x4 1/4" wall tube. Sealed, with 3/4" clevis mounts welded through. Waiting for my 5/8" D-rings in the mail to finish it off. I made it so that the clevis mounts bolt directly to the frame extensions so that the load will be on the frame rather than the welds. I'd like a hoop on top, but that'll come later. It's made to basically bolt right on to the stock holes with minor drilling.
It's only 46" wide which seems small with these little 32s but hopefully with some bigger meats it'll be more proportioned. I also think I would rather have gone with 2x5 inch, it seems a little narrow too. With 1/4" walls it should be upto some rock bashing though. Not that I ever get to actually do any, k maybe a little.
Whaddya think. Too small? Also, being that I've never had a winch, does it look like a winch mount will bolt on top of it without too much trouble?
Thanks
I think it looks GREAT!
Simple and clean, I like that, like you, I would like to see a hoop up front... especially if you plan on a winch later too, you could remont the lights onto the hoop as well.
Looks great man, I really like the idea to bolt the shackle hangers from the frame, should be very stout!
Rezarf <><
Good looking bumper. Good thinking on the Clevis mounts
Excellent job on the bumper! Now, the way you mounted it using that bar stock doesn't look like you put too much thought into that part. What type of winch do you plan on using? Upright or low profile? My thoughts on front tow or extraction tabs should be mounted firmly to the frame, not the bumper, so I went through the bumper to the frame. I guess you could say I don't trust my welds. I built 2 shackle type mounts & used some 3/4" grade 8 bolts to secure to the boxed in frame:
Huh? :confused: It's mounted with more than just the bar stock, not sure what you're sayin man. :)
I'd like an 8274 like yours. I like the way your turned out. :beer:
I guess what I shoulda said was I think your bumper can withstand more loads due to the design of being a boxed style. Mine is just a "c" channel which is why I decided to go through the bumper to the frame. I only wanted the winch load on my bumper, not for extraction purposes. Kinda silly thinkin, but I'll run it....
Look again Hamma. He DID take the clevis mounts through the bumper to the frame, bolted and welded. Inside the frame rails find the bolted thru mounts.
