Budget mm hydraulic
You do not need to upgrade to get full pulling power...is what I am saying.
I completely agree, which is why I just upgraded my stock pump to a Saginaw unit. By doing that I was hoping that I can get the full pulling potential out of the winch, so I guess we'll see.
My hydro setup will be the Saginaw, MM Hydro winch and a hydro assist ram on the front axle. Wondering if that will work out or not:hhmm:
Specs are on the website in PDF Format. Mine fit an ARB in front and a 4x4 Labs in the back with no problems.
One question to you guys with the 10k or 12k MM Hydro winches. Can you do some measurements for me? I need the dimensions of the winch to see if it will fit in my bumper. I would like the length height and width of the winch, with or without the solenoid pack. Thanks!
:cheers:
Where are you guys getting your PSI output numbers from?
MM claims that all PS Pumps put out around 1,500psi and 4gpm on average.
I read somewhere on MUD that the FSM says the pump is 1,350psi Minimum which most likely means it is in the 1,500psi range.
I have not confirmed this but MM was VERY confident about the 1,500psi and 4gpm rating of the power steering pump in just about all vehicles.
From the "Service Specifications - Steering" of my 96 FSM:
Fluid pressure at idle speed with valve closed: Minimum 1351psi
