BS for 15" wheels ?
I understand that older or non-elockered 80 Series came stock with 15" wheels, but for the ones that had 16" as stock, has anybody run 15" wheels on an 80 series that god made with 16" wheels?
Can anybody tell me the 15" BS that will work with the calipers used under the 16" wheel?
ONLY a steel 15" wheel with a 3.5" back space will work with a little grinding on the caliper.
Any further in will require to much metal to be removed. Any further out will have tire rubing problems while tucking in the tire.
GW, why only steel wheel ?
Just rubbing ?
Brake clearances should not be effected right ?
steel wheel material is not as thick as the alloy toyota one so there's more clearance
