Brown bvsv confusion
I've got a 78 desmogged with 2f and stock carb. Finally got it purring like a kitten a couple of weeks ago and then developed what seemed like a big vac leak. Wouldn't idle and surging. Noticed I'd somehow broken one of the nipples off the brown Bvsv. Wouldn't think that would cause my symptoms as I though that would just open at operating temp and under throttle. Capped off that port on the carb and still won't idle. Am I wrong? Don't see how capping off that port to the bvsv would cause my issues. I'm getting plenty of fuel.
Here’s what I found on desmogged 78
The brown one controls the temp at which the charcoal cannister can purge when off idle. I agree with you, it seems if you plugged the vacuum source at the carb, and don’t have it routed to the VCV, the vcv won’t open the CC cannister to the carb. If the vcv was broken/leaking, you should have had these issues before breaking the bvsv, but I guess there would be no harm in checking the vcv to make sure it isn’t leaking, that could cause your symptoms but so could many things.
I’d back up and check your vacuum reading, maybe something else got pulled off or broken when that one did.
From posting titled Layout for 78 desmog:
Edit from previous posting: The only thing stopping it from purging is the bvsv, when cold, and the throttle valve being closed at idle. When off idle and bvsv is working, the ported vacuum coming from the base of the carb is applied to the s port on the vcv which then opens the purge port to your intake. The truck will run poorly is it is purging at idle or when it’s cold hence the need for ported vacuum and the bvsv valve.
Now that all makes sense. Thanks. I Must have an issue with the carb not related to the bvsv. Thanks.
I have a 60 but here are my notes on that circuit. See the green boxed area. When the car is off the the solenoid opens the carb vapors to the CC. That’s so when the car is hot and shut down the gas vaporizes and can be captured by the CC. When the car is on, the port is closed by the solenoid.
