Does anyone by chance know if these are original Toyota rims? Ive looked around and seen what looked exactly like these in a few restored pickups. Would be really cool if they are, then i will invest some money in them and get them powder coated. I will scrap some more goop off them and see if i can see any numbers anywhere. Appreciate any info guys!
Well i poured some gas in the carb and with a fresh battery she fired up to my surprise! Starter is barely hanging in there, i had to have someone hold it in place with a stick to get her to turn over, previous owner ruined every bolt. So im probably only going to keep the 20R head and junk the block and the trans. I am crossing my fingers that the transfer case is in good working shape and not to much wear, i really need some good parts out of her for my dual setup on my 82. Windshield washer reservoir is in great shape to, not cracked or rotted or damaged in any way. It may have had an aftermarket ac at one point, only trace is the mounting bracket on the block.
Floors are definitely rotted through, so only the top part of the cab is really usable. So anyone looking for pieces or parts on here feel free to ask, chances are im probably going to scrap the whole cab and bed and frame, so it will most likely be free if you can use it. There is another member on here that layed claim to part of the frame.
Might try and sell the gauge cluster or just give it away to someone in need, its in perfect shape. I will probably keep the blue bezel and glass on the gauge though. Left side trim panel seems to look good, i wont ever use it because its gray. I believe this truck has the 4.37 R&P if im correct? It was built in SEPT 79. I plan on getting the drive train pulled by tommorow and the cab stripped.
