Broken
Western Slope, CO
Ok I need to replace my rear pinion shaft....:frown:
Can anyone tell me if I can swap a complete third from a front axle??:confused:
This is for a 74, think it's a course spline?? Anyway the story is...
Just completed a SOA, fliped springs, issues with shackles inverting see earlier post. So I got the rear driveline in today and took it for a test run, everything was fine until I hit the brakes...:crybaby:
Well the shackles rotated which cause the pinion angle to point at the ground, which caused a severe angle on the rear shaft...well you get the picture. Snapped the pinion shaft like a twig.
74 will be coarse spline pinion, and yes the entire front center will swap into the rear...just be sure to transfer over the center block from the busted rear (keeps the c-clips retained)
69-77 will swap in, no problem...side and pinion gears splined identical...
You should really post up some pictures of your rear suspension configuration....I am certian that I am not the only person currious about this.
Ok I will get pics up shortly. Thanks for the replies, The rear suspension has been giving me troubles since day one. At least I have another axle handy. Also I put an Aussie locker in the rear, so What would be the best way to make the swap? So far looks like just the pinion is damaged.
Maybe this will help explain some things, even after I pry the shackles back down it seems to want to pull back to where it was before.
They were that way to begin with and did NOTHING to correct the problem. So not knowing I reversed them to what you see now. I actually did not notice any difference in them either way.
Like this??
then it sounds like you may have another issue.:whoops: put them back the first way as shown in that picture.
wtmtnterror said:
Like this??
No that's not the same.. Look closer
Where is your anti-wrap bar? I think that may be the issue.
1> horsehead has the only pic with correctly installed anti-inversion shackles
2> SOA = required anti-wrap bar.... (IMO, of course)
Again, you need a torque bar and your shackles installed correctly. It is amazing how many people put those anti inversion shackles on backwards or upside down.
I understand the reason behind the anti-wrap bar...but I was having a problem with the shackles rotating up even before I did the SOA?
Here is an older pic I found before going SO
It looks to me like those are on upside down in this picture. Using Horsehead's picture as the "correct" installation. Examine the differences in the pic from Horsehead and the yours...when you see the difference you will know it :)
and again, they are not installed correctly in that picture.
