Broken side view mirror
My passenger side view mirror fell out of the case the other day. It looks like there are two tabs that are on top that broke and possibly a screw that should be in the bottom that is gone. Anyone know where to get a replacement, or a fix?
Talk to CDan @ American Toyota (Vendor Page).
I believe you have to replace the whole thing. Search for shakey mirrors, you'll find a whole thread on how it all goes together. Those tabs are a common problem. One of mine is broke, but the other tab and screw are holding in place.
May be able to fix it like other have done in that thread.
I fixed mine with a short piece of copper wiring (12 or 14 guage). Where the tab(s) are broken, drill holes into the plastic where the tabs should be. They whole should be the same size as the wire, or a tad smaller. Bend the copper wire into a U shape, put some glue on it and stick it in the holes. Bend the wire so it has about the same clearances as the broken tab. Let me go grab a pic of what I talking about. You can see on the right side where I tried using epoxy to form the shape of the tab, dont bother it will eventually just break off. The key is to just get the top of the wire at about the same height the plastic tab was at, so you can hook it on the hooks inside the side view mirror (see the red arrows). When you put the screw back in the bottom it will pull the mirror down. If it wigles you can bend the copper wires back toward the mirror a bit so it fits tight when hooked over the hooks.
hth
