Broken mirror glass replacement.
Did some maintenance on my bro in law's 93 with 330,000 miles on it this weekend. One item I wanted to do was replace his broken passenger mirror glass. I was going to try to cut a piece of mirror and just glue it in place but a chance encounter made this easier.
Found out that a lot of auto glass companies can get the glass alone and some in bigger cities actually can cut it while you wait. My local shop had it same day for $30. I talked them down to $20 without install as I was envisioning simply glueing it to the backing. Not exactly.
The guy at the shop was so helpful he offered to install it in the parking lot. A trick was not to use the supplied double stick mounting film as you only get one chance to do it right and he says that's difficult. He recommended using silicone adhesive which lets you move it around before it dries. The 80 has a tough little lip the entire perimeter of the mirror, which he could not do in the parking lot so we brought the mirror guts inside (fortunately I arrived with the old mirror removed and the guts cleaned and prepped). He then proceeded to struggle with that plastic lip for a good 15 loooooooong minutes on the bench and he was their resident expert and quite good. But that lip is stiff.
Anyhow, for $20 I was very pleased as the glass is convex and has the legend "Objects in mirror..." exactly like factory. Not bad for same day, too. But be forewarned on the difficulty and don't expect to be able to do it in the mirror housing due to the force required to deal with the lip. He said using a hair dryer to warm the plastic lip helps and used a stiff thin plastic blade to get the lip up and over. I wonder if a tough thin twine would pull the lip up like that used in windshield seals to pull the lip up.
Got the mirror to stop wobbling as well. It had one of the 2 ears snapped off, so Cdan shared a trick where you use double stick foam tape to hold that side. I used 3M's foam tape but I use the thinner stuff and before removing the plastic film I trial fitted the mirror. Found I needed two layers, which approximates the thickness of typical household white foam tape.
DougM
nice tip!
:cool:
