broken hub bolts
Hermiston, OR
So I was looking at my hub today and relized that a stud was broken. I pulled the hub off and two other studs broke and the dowel pin was broken. This is a 79+ 40 axle with factory disk stuff.
I tried ez outting the studs but the threads are all messed up right at the end and I cant get them all the way out without drilling them completely and taping the hoes bigger.
My question is are mini spindles (or whatever there called) the same? Ive got some extra mini solid axle parts and IFS parts. If I just swap my vented rotor to a new spindle will that work?
Justin
The mini truck hub will work, but if your rotor is retained to the hub by six 10mm bolts, then you will need to get a 1980 and later Land Cruiser rotor and press the studs out of the mini hub, remove the two 10m bolts that hold the rotor onto the hub, and replace the non-vented rotor that is thinner, with the vented, thicker Land Cruiser rotor.
No big deal...
Good luck!
-Steve
jnau99 said:
i'll have to look at it again. But my rotor is vented. And my knuckles use the large bolt patern.
Thanks
The bolt pattern of your knuckles, large or small, has nothing to do with your rotor being retained on the hub by six 10mm bolts (pre 1980 style) or by the six wheel studs and two 10mm bolts, (1980 and later style) or if it is vented. All Land Cruiser rotors were vented. All pre-1986, solid front axle mini trucks used sold non-vented rotors and a caliper with a smaller opening for the rotor to fit into. Mini-truck calipers are not compatible with the thicker, vented rotors, until 1986 when Toyota changed the mini-trucks to IFS in the North American Market.
You can use the mini-truck hub, bearings and seals on the Land Cruiser spindle, as these parts are all compatible. If you decide to use the min-truck hub, you will need to change the rotor over, and what I am telling you is that the one that is currently on your damaged hub, likely will not be compatible with the mini-truck hub, which will force you to find the later Land Cruiser rotor and install it on the mini-hub after removing the mini-truck rotor, since that solid, non-vented mini-truck rotor is not compatible with your stock Land Cruiser caliper.
Good luck!
-Steve
