Broken Fuel Door Lower Hinge
Columbia, MO
As the title implies, the lower hinge on my fuel door gave way. Was wondering if anybody else has experienced this and what their solution was. It looks like the "hinge plate" pin may slide out and allow a new hinge plate to be mounted to the fuel door. Does anybody know if this part is available? I suppose I could take the entire assembly off and weld the hinge back.
Thanks.
--Mark
I welded mine. Shouldn't take much more than a spot weld.
You know you get bad gas mileage when the fuel door breaks. :flipoff2:
My usual shop put a big ole' nasty weld on it for free. Holding up well so far. ;)
