broken e-locker help!!!!
washington
first I bought a 135k unlocked 95 land cruiser, found locking axles. I put in the rear axle wired it to the factory harness, rebuilt the rear actuator, that was the easy part. Then move to the front.....since the axle was out of a wrecked cruiser I used my front housing and with a little machining and drilling installed the carrier. but it drove weird? knowing that is wasn't right tore it apart and found a broken spider gear deep inside:( First can i get another part from someone, Please!!!!! also i'm concerned that the carrier got hot and has deformed, because the big bearing race is Slightly loose, not sloppy just loose. so, is it garbage, or keep moving forward.. if I can't get a new part then I guess I'm S,O,L......help
I can't say who all has bent a front axle housing (I have & Christo says he's done a few) - but maybe it was driven after wreck for a period of time (total guess) - I shattered the inner drive cuff the driveshaft slides into, and ate a bunch of splines off the inner shaft too.
I've no idea if they are cross compatible, but how about using your old 3d member for parts? I had the last NIB locker 3rd sent my way b/c Ben @ Slee got it somehow, but maybe even a shop like Just Differentials in Cashmere has some parts around as they bought my old 3rd despite the problems.
I mention them as you have WA as your location, so if you're West coast WA & not D.C. - the shipping is cheap if you can source parts from them, or as e-lockers are a complicated animal, ship your haggard unit to them & get it worked over.
I have short of 10 R&P's to my name, but even @cruiserdan told me the smart money with e-lockers was to get it done by one of the top shops in your region, if you're up here with me then J.D. is ours.
I hated cutting a check but I can't argue the results, one of the only times I paid for labor. But I'd do it again - I think it's safe to defer to Dan when he says "cut the check". Esp you where maybe the full 3rd has issues only Magnaflux would find, and as a simple smart $$ you want to either just buy a new inner shaft or check the snot out of yours.
As much as mine was chewed with a 3/8" housing bend I'd just pay for a shaft, seems it was under $150, or so. A little scotchbrite & steel wool to the seal surface & you can even run OE 'Yota seals. My casting / milling there was a little rough, YMMV.
The difficult part is that the carrier and the locking side gear are specific to the oem locker, and they fail pretty often. So if we end up with parts of 3rd members, these are the pieces that are usually bad. Otherwise we have complete OEM locker 3rd member cores, but he carrier, 3rd member housing, spider gears all need to stay together or they are unusable.
I actually like them myself, and totally worth running if you have them already or get a really good deal on them. but they do have their fare share of issues. We see the ones with issues, and we run into people often that have purchased them for a swap, hoping to save $. Problem is that some of the components aren't readily available that go bad, front is a weaker design, and the rears tend to twist axle shafts. Again, I'm not bashing them. I like them more or less, and have run them in several of my own vehicles.
OEM lockers perhaps not your favorite?
I equate this to most issues on an 80 being reported here on 'mud. People tend to only post when problems arise.
Can you send an email to carl@justdifferentials.com I may have something for you
first I bought a 135k unlocked 95 land cruiser, found locking axles. I put in the rear axle wired it to the factory harness, rebuilt the rear actuator, that was the easy part. Then move to the front.....since the axle was out of a wrecked cruiser I used my front housing and with a little machining and drilling installed the carrier. but it drove weird? knowing that is wasn't right tore it apart and found a broken spider gear deep inside:( First can i get another part from someone, Please!!!!! also i'm concerned that the carrier got hot and has deformed, because the big bearing race is Slightly loose, not sloppy just loose. so, is it garbage, or keep moving forward.. if I can't get a new part then I guess I'm S,O,L......helpView attachment 1374793 View attachment 1374794View attachment 1374797 View attachment 1374798 View attachment 1374795
