Hit a bird doing 75 and it snapped my antenna. You can kinda see the piece thats stuck. How can I fix it or would it be better just to replace it with a short rubber antenna?
You don't mention what year but if it is a later model year look here:
Power Antenna Mast Replacement
You might be able to get away with just powering out the old mast and cable all the way and then power the new one on...Unless you have an earlier year where the cable is attached.
HA! A bird killed the antenna on my '97 as well... That's kinda funny.
hopefully not he one in his avatar ;P
I finally replaced the one on my '97 last night and it was a piece of cake. Just follow the link that's provided above. Only problem I had was the antenna didn't retract all the way using the down button. Once I turned the radio off it went all the way down. This wasn't mentioned in the link above.
Hm, interesting. My replacement on my '97 lx450 a couple years ago went exactly as you describe w/ the incomplete retraction. I thought I somehow didn't do the install correctly, but since it worked fine when I turned the radio on & off, I didn't worry too much about it. Guess we either both did it right or we both did it wrong.
its a 97...
Approx. 30 min. The part that took the longest was cleaning out the old grease in the motor housing.
- That just proves to me I am one slooooow
I was kind of rushing because I did it before going to bed. My wife was not happy sitting in the passenger side waiting to push the buttons for me.![]()
