Bright Lights won't work
STL> MISSOURI
If I pull my light indicator back the brights work, but if I click
it forward into the bright position its stays, but the lights do not
work. Is there a small part to replace or do I need the
whole indicator? blinkers work! lights work! If I need the whole
shooting match, Is this part on other toy trucks?
Thanks in advance
1997 TLC:crybaby:
Needs a new switch. Not sure on the part #, but I had the same issue.
same issue here. hopefully the part is cheap, as i was just informed by the boss that the lc is cut off from the checkbook for a while.
