Breaking loose the LSPV
Washington, MO
I'm trying to lower my lspv valve in the bracket the previously mentioned 0.25".(Post OME)
The nuts loosen fine, but the bolt is frozen to the bracket. I tried wacking the end of the bolt with the nuts protecting the threads. I've sprayed penetrant. I also tried prying the LSPV away from the bracket.
Have I began a waiting game for the bolts to be "penetrated"? or is there some magic trick to freeing it up from the braket. I only see 2 bolts. Am I missing one? It's not that rusty, but there is a white crud around the base of the LSPV the back side of the bolts.
There are 4 bolts. Two that are visible from the rear of the truck that thread up into the frame and two that thread through the front with a set plate from the rear. Instead of lowering the unit you could raise the shackel bracket the height of your lift or use the set screw in the second shackle the same height of the lift. when I lifted my rig I measured the height of the lift and added on tho the shackle bracket that connects to the rear axle. When I lifted my 4Runner they sent a bracket to extend the shackle from the axle. That seems to be a much better way of making accurate adjustments rather than guessing on the proper drop for the LSPV???!!! Just a thought. This info is on page BR53-55 in the 1994 FSM should be the same as the 96. Good Luck.
The penetrant worked on the valve bolts.
Finally after almost 3 weeks, the penetrant soaked in. I adjusted the LSPV valve down .25".
The post OME braking was definately different than before. It was squirrley for lack of a better term. It seemed to catch in the 18 wheeler grooves at stop lights. Now that I adjusted the valve , everything is straight and normal. I was going to make a bracket for the back of the axle when the penetrant didn't seem to be working, but I became sidetracked and decided to give it one more try. I'm satisfied with the results.
Hopefully, if I did it correctly, there won't be any abnormal rear brake wear.
:beer:
