Break issues
Kodiak AK
I have changed the front and rear calipers, rotors, and pads after them seizing. Now when driving, pressure builds up in the system and stops the vehicle. Brake pedal feels like a rock. I was able to bleed all 4 and would do this to relieve pressure to get home. What do you guys think? 1997 FZJ80
You still have air in the lines and it is expanding as it heats, then applies the BRAKES as the bubbles expand.
Bleed the BRAKES in the proper order and do more than what you think it takes. You will also need to activate the ABS in between bleeding.
Did you mess with the master or booster? That is often the push rod adjustment, not allowing the master to fully retract.
Ok sounds good I’ll try that today. Appreciate it and I’ll let you know.
Nope, didn’t touch either of them
With the pedal fully released, the system should not be able to build pressure, it should be relived by the return port to the reservoir. That port can be blocked by the push rod being out of adjustment or seal dieing in the master.
There is also the LSPV that usually gets ignored (need to make sure you bleed it also). I just had to change out my brake booster (pedal took both feet to press). After that all has been good.
