I ended up completing it (half gallon of brake fluid later) after I figured out what was wrong.
Good luck if you try it yourself and be patient and if you go to a Toyota stealership it wil cost around $106 to have them just bleed it.
Thanks for the vote of confidence Ebag333
I feel better now, it took me about 1.5 for 2 nights in a row for a total of 3 hours. At least I know what I did wrong now.
That is a big dude in the drivers seat, is his head touching the roof?
I don't know why it is in that order because usually you start with the furthest out and work your way to the closest and the LSPV is certainly further than the front calipers but whadda I know...It has worked for me 3 times now though using both the helper method and when using a Motive Power Bleeder.
