Brakes
Calgary
What's the go 100 series pads on the front or just go ebc yellowstuff pads & rotor?
Or maybe 100 series yellowstuff pads on 80 rotors 🤔
I have heard the 97 Land Cruiser pads are the hardest but not sure if that is true.
I personally run the Power Stop E36 Extreame Off Road/Towing pads and love them. When properly bedded they grab like a modern day vehicle.
OEM is the way to go. I like 04465-60020, Toyota/NBK pads on the front.
I personally stopped running the 100 series pad, the only real benefit is pad life.
Right now I have Akebono ceramics on all 4 corners and have been happy with them, in the past used ADVICS and OEM. RockAuto has very good prices on brake parts if you go aftermarket. Best recommendation I can make about these rigs, is to properly maintain your braking system, and to make sure everything is properly adjusted. Quality pads, fresh brake fluid.
I just ordered the Z36's for the first time. Plan on installing them this weekend.
Make sure you follow Power Stops bedding process. I found an open parking lot so I wouldn't hold up traffic or speed around my neighborhood.
  • Like
Reactions: b16
