Brakes again
Orlando, Fl
a trusted mechanic of mine says that the two rear wheel cylinders are shot, is this a common problem with drumbrakes all around?
yup. On mine atleast. IMHO the stock brakes are a pain inthe arse and junk. Sure they stop well, but maintaining them is too much effort.
You can get replacement ones from many places though, such as Cool Cruisers. They are such a popular replacement part that Cool Cruisers sells them in kits. Be sure to get the right cylinder for the wheel youre replacing them for since there are different ones for different sides of the rig.
If you want to upgrade and just be done with them, put Monte Carlo disks on back. Cost can be anywhere from around $150 or less if you scrounge parts from a wrecking yard and buy the plate, to maybe $500 for everything brand new. There are many tech articles on the conversion under the Technical Links link above.
I am in the process of gathering all the parts for the disk conversion.
good luck-
Dustin
i've been thinking about gathering up the parts for a axel swap from an early mini, but i dont know exactly whats involved in that. and at the moment im just trying to keep it drivable for longer than two weeks.
