Brakeline routing
Kansastitty
I'm plumbing a new master cylinder and running all new brakelines. Instead of running the front circuit across the firewall, I'm going down the driver's side frame rail (like the old single circuit master) and around the fron crossmember to the passenger side to make the drop to the axle with the flex. The axle is out of a '77. I need to go inboard of the shock tower or outboard of it. I can see hazards either way.
Any suggestions? I don't even remember how the old one was routed, but I think it was inside.
Thanks,
Ed
the old one is no top of the fram rail, going around under the bib and then down the passenger side past the shock tower on the inside coming out behind the shock tower. If you want a pic let me know
