I just replaced the front brake warning switch on my 1974 FJ40. Simultaneously, I replaced the rear brake cylinders. So now I'm into bleeding ops...which aren't going great. Fluid drained out of the bottom of the brake master during the switch replacement. Did I buy myself a master bleed operation? I'm still getting a touch of air out of the lines but pedal goes to the floor on the first pump, then firms up. I don't want to burn too many points with the wife if I really need to double back and bleed the master first then the lines.
Thanks!
Thanks!
