Brake thingy ??
denver
Anyone know what this thing is. I recently swapped to fj60 axles and redid all the brake lines since I had a single circuit system before. I didn't know what this thing was so I left it in the circuit. 12/69 fj40
Sorry about the blurry pic
It's a tee to split off each of the front brakes. What did you use to replace it?
That’s all it is? I just reused it since I had no idea what it was. I guess it is just not drilled and taped for actual splitting and is just a brake in the lines to run to the rear brakes. I now know where my proportioning valve is going to go if I decide I do need one. :) My brakes feel better every time I push them, it is stopping very well and I am happy. :bounce:
I just wanted to make sure I didn't have something crazy in there.
Yep, untapped T. So, what did you end up using for the master and overall setup?
I ended up fitting the mini master and booster up to the firewall, it wasn't as big a PITA as I thought it would be. The clutch master is resting against the booster so I may try and find a small fj60 clutch master. It Stops very well although I think I most likly need a porportioning valve. I do need to bleed the brakes some more as they are a little spongy. No pumping needed, brakes are always right there.
FJ60 axles so 4 piston calipers with vented rotors and single cylinder rear drums.
Here is a link to my build
