contemplating some axle changes brought up an interesting idea.
if i had a 60 series rear axle with the park brake, would it be a bolt-on swap (aside from the e-brake fab) to swap backing plates and brake guts with a non-park-brake rear 40 axle? since everything seems so interchangeable from 40 to 60 series, it seemed like the housings should accept either backing plate without issue. i am guessing the axles are the same, just longer for the 60 than the 40. am i way off base here?
get the e-brake rear axle without having to scrounge for a post-79 axle, no need for the PITA t-case park brake.
