brake stuff
Strawberry, AZ
ok so the last couple brake threads perked me up for this Q. i got a 76 cruiser and a 83 master, for some reason the front line threaded right in but the back line is just a hair too big to thread. what is that size? i know it should be 10mm but maybe its 11mm?? has anyone seen this? i went to check out adapters but i'm not sure what i'm gonna need other than to start buying and testing them.
It has been over-tightened and that is why it will not just thread right in...the end is mushroomed out causing the interference...
It is a 10mm fitting, just like the front....you may need to make a new line.....
Good luck!
-Steve
andrewfarmer said:
You can file the end gently to let it fit again - just avoid getting any filings down the pipe :)
make sure to file it till it fits ALL the way to the threads without turning untill you're at those threads...I didn't file mine enough and it ruined my new master!!!(:mad: come to find out the seal at the front of it was toast anyway:mad:)
