Brake Shudder
The Buttcrack of Idaho
The 80 is finally back on the road (Thanks CDan). And big time thanks to ToothFairy.
However I have a one more problem that is unrelated to the repairs I just made.
When coming to a stop, just short of a complete stop, I get a shudder that feels like the ABS is activating. I also get a mometary pull to one side when it does this.
Help Please
Jay
mine does the same thing, feels like the abs kicks in right before complete stop, actualy causing the vehicle to continue a couple extra feet. It does not pull to one side when it does it though, I posted about this around a year ago, did not get any real good ideas as to what may be causing it, my best guess was warped rotors, I replaced the rotors and the pads, still did it, maybe we can have better luck with this post, sorry I could not be of more help, still looking for some answers myself.
Same problem here.
I just bought a caliper rebuild kit, I think one of my front pistons isn't retracting properly, which is causing my truck to behave the same as yours.
BTW when describing the "shutter" have you noticed that this effect is more prevalent going down hills while braking?
FWIW, My pads/rotors are fine just like FXJ and I just installed an OME shock/spring/dampner/HD tie rod kit. I also had my master cyclinder replaced for a different problem.
Jay/FZJ,
If indeed your ABS is the problem, prepare to shell out big time. Determine if this is the case by pulling the ABS fuse and driving around with normal brakes for a while to know. The ABS light will illuminate. If the problem goes away, then get back to us and there are some cheap things to check on the system first - you might get lucky. But I suspect there will be no change and it will be a cheaper brake issue vs ABS problems (very uncommon to truly have an ABS issue on this vehicle).
DougM
Maybe a silly question, but are your brake calipers tight?
Sorry for the slow reaction time but works been a load.
I removed the fuse on the ABS lastnight and the problem is 100% gone. No more brake pull to one side, and no more shudder.
Now, any ideas where to start diagnosing it. The pull was to the left so I'm assuming the problem has to be the right front tire. But what could cause it.
Note: Use caution when pulling the ABS fuse, apparently Toyota strategically placed a hole in the inner fender that will swallow your fuse when it pops out. OOPS
>> But what could cause it. <<
See TF's post above.
-B-
You mention repairs you just made. By chance did you do some front axle work?
DougM
Repairs, New Radiator
Fanclutch
Hoses & Belts
PCV & Grommet
Again thanks CDan
The other issue we found on it was a bone head mechanic had replaced 2 of the lower knuckle arm studs and then jammed ASE fine thread knuts over them with locktight, luckily the studs were still ok. Also one of the wiper seal bolts had been snapped off.
Incidently this is the same wheel that seems to have the ABS malfunction in it. Is it possible that he also damaged the sensor. Does a damaged sensor trigger the ABS dash light.
Jay, did you ever get resolution?
Today I noticed the same symptoms (ABS type shudder in pedal right before complete stop) you mentioned in this thread.
If anyone else has experienced similar please comment.
For reference my rig:
Front rotors and pads less than 8k miles of easy driving.
Rear rotors and pads less than 1k.
Brake fluid at or slightly above max line.
Less than 8k on properly maintained and rotated KO2s.
I have not yet pulled ABS fuse to check for relief of pedal shudder.
