brake rotor replacement
does anyone have a write up on how to change the brake rotors? i couldnt find one in the faqs...it looks like there is alot involved so any tips or advice would be great :)
Search in the 80's section will find you a wealth of info. Front or rear specific will narrow the search. Rears are very easy, fronts are a little more work!
I just did this about a month ago. In the FAQ there is a complete front axle rebuild write up in the maintenance section. I just followed the writeup until the rotors were off then greased everything and put it back together.
i did mine several months ago, and I haven't regretted the decision one bit.
before:
after:
I already know the rotors are backwards, there is a method to my madness, so I dont need anyone to point out to me that they are. I know there is also High Temp RTV there, but the factory gaskets are there as well, I just wanted to keep as much moisture out as possible from this side. If you're going to do you rotors, you might as well do a front end rebuild. you'll already have it mostly apart.
take your time and pay attention to how things come apart if this is your first time. I've doen several rebuild and it only took me about 2 hrs to do both sides, but I've done several of these on all my Cruiser's.
good luck.
