Brake question
Hi guys!
The rear brake cylinders of my bj40 are in real bad condition almost unuseable tried everywhere but can't find the replacement cylinders in this part of the world.
One of the options I'm left with is swaping the backing plate for a pair from a 60 series or a 75 series for which the cylinder are readyly available. but since these use a four bolt setup (compaired to the six bolts in the 40) the only way to do this is to grind the 40 anchor and weld on a "four bolt" type backplate anchor onto the differential (axel) housing.
1. Is there any other better way out of this problem
2. would the welded joint be strong enough / safe
hope you guys have some ideas
Where is "This part of the world?"
Can you get them apart and rebuild them?
I got tired of messing with mine and am going to disks. Got all the parts - just no time...
if it's something easy like canada, here:
http://store.4wheelauto.com/index.php?cat_id=45&catname='Brake%20'
most auto parts stores should be able to hook you up with a rebuild kit at least, likely special order but... or there's always the dealer. I guess one problem might be that you are looking for parts for a bj40, which would quite likely be the same as an fj40, a more common model. find out if they are the same, and what other models cross to the same cylinders.
Try www.sor.com. I know that they will ship worldwide. I'm sure that they will have the part that you want. No affiliation here other than a satisfied customer.
