Brake question....
Richmond, va
I have recently replaced my front rotors and used 100 series pads. My brakes worked great before I changed the rotors and pads, except the rotors were warped. SO after the change if I hit the brakes very hard and fast, as in a panic stop, the pedal feels extremely stiff, and does NOT stop like it should at all. On the other hand if I apply slow steady pressure to the pedal they seem to stop just fine. It is only when I apply the brakes like I would in a panic stop do they not work nearly as well.
With the truck running the pedal does slowly move down, does this point to the MC being bad? Or is there another problem. I did not bleed the lines which I intend to do shortly, just curious if anyone had any other suggestions.
Steven
i would've bled the brakes before anything, i thought this was just common to do after replacing pads. i have never known any different!
Well I honestly thought it was better to bleed them, and I usually do, BUT the lines were not opened so no air was introduced, so I thought it would be okay. The only thing that gets me is how hard the pedal is to push. I can even use both feet and it still won't stop.
x3 on bleeding the brakes. I just replaced the front rotors and pads on my 80 and although the system was not opened at anytime the pedal was mush. Great time to flush the fluid as well and get all nice clean fluid in there.
Other than that did you thoroughly clean off the new rotors with brake clean and bed in the pads with the rotors?
