Brake Problem
Corpus Christi, Texas
97 Land Cruiser
Brake peddle hard to push and barley stops vehicle, pedal goes low to the floor
No lose of fluid, good pads and bled system problem still there
Thought it might be power booster, I hear no hiss or leak when pushed
Removed check valve and booster still held slight vacuum
Since the system has no external fluid leaks I'm thinking it might be an internal leak in the master cylinders??
What is the best way to check the vacuum booster to rule out
Thanks for the help
I had a brake problem a couple of weeks ago. Had similar symptoms. It was barely stopping, and also having weird issues with the anti-lock system.
My problem was that the outer bearing on one of my front axles had gone bad. The friction from the barely moving bearing had caused the axle shaft nuts to back off some. This caused the wheel to wobble. The wobble caused the brake disc to continually push the pistons on the brake caliper all the way in, so when I pushed the brake pedal, there was no contact between the pad and the disc.
Took me a little while to figure it out. If you want to check that, all you have to do is take off the dust cover at the end of the axle. You will be able to see if the axle nuts are in proper place or backed off.
Don't know it this will help you, but a new bearing fixed all my problems.
Good luck!
Kent
