I have a 1984 toyota pickup. When i first got it. It barely had any brakes. You had to pump them 2 to 3 times to get brakes. So i replaced the master cylinder. Which made it even worse. So maybe its the brake booster. 1 brake booster later still the same problem. Excpet now i have to pump the brakes 4 to 5 times to get anything. Then when i rev the motor all brakes are lost. Ive checked all the vacuum lines. Brakes lines. Nothings leaking at all. I have aboslutely no clue as to what needs to be done next. Theres solid fluid out of every bleeder even the LSPV. Its got the 22r motor in it. If youbgusy could please point me in the right direction that would be much appreciated.
Id start by giving them a realy good bleed.
Pump the pedal 4 or 5 times and hold it down and get somone to open the bleed nipple,repeat this several times each wheel and keep toping up the fluid.
I know youve replaced everything but it does sound like traped air to me
I've got an '86 4Runner, 22re. Sounds like air in the system, most likely the master cylinder. A few questions:
Did you bench bleed the master cylinder? You really can't get the air out of it by bleeding the lines. If you didn't do it, there's your problem. The good news is that I can tell you a simple way to do it without removing the MC and brake booster. The bad news is that there's a good chance that the problem to begin with was air in the system (and you didn't need a new MC or booster )
And while we're talking about your malfunctioning brakes...
How did the brake fluid look when you bled the system? Was it really dark and burned?
Did you do anything else to the brakes? Replace or rebuild the calipers or the drum cylinders? New pads, rotors, shoes, or drums?
