Brake pedal gets soft when warm outside
our new LX is like that, the pedal gets higher on the 2nd pump. I am gonna have the no name brake shop work redone and use OEM pads and bleed it right.
spressomon said:
Do you automatically bleed the brake booster as apart of bleeding each wheel brake cylinder? Or is there a different, extra step/process to bleed the brake booster (and if so what is the process)?
I have bled my wheel cylinders, using speed bleeders; replacing the brake fluid as well. The brake pedal 'feel' is better than before however it is still more positive on the second pump of the pedal; wondering if it might be the brake booster or???
FYI: I pumped each wheel cylinder approximately 30-times for each...
