brake parts interchangability.
Utah
I just picked up a set of FJ60 axles that I will use for my spring over.
These axles need to be completely rebuilt.
About 6 months ago, I replaced all of my front disc brakes on my 76 FJ40 with new OEM parts for a 76 FJ40. ie new caliper hard lines, new calipers, new rotors, new pads, etc.
Will the 76 FJ40 brake parts swap over to the FJ60 knuckles and wheel hubs, or will I need to swap the spindles-out from the 76 axle for this to work???
Thanks!!!
The only differences with the 1976 Land Cruiser disc brake axle are:
Knuckles-
Knuckle bolt pattern is larger and steering arms on the 60 series are stronger than your 1976 disc brake knuckles and arms, however, to use the 60 series steering arm with 40 series steering components will require a bushing/spacer in the steering arm to take up the difference in diameter between the tie rod ends....no biggie.
Dust shield-
Tee fitting that the hose attaches to on the 60 series between the axle housing and the knuckle is rivited in place, compared to the bolt on style on the earlier axle housing. Your earlier dust shield will bolt onto the 60 series spindle/knuckle no problem..
Hub and rotors-
The rotor on the 60 series is compatible with your caliper on the 1976 front axle along with the spindle, however, the rotor is held onto the hub with two 10mmx1.25 diameter bolts along with the wheel studs, opposed to just being bolted to the hub on the 1976 with six 10mmx1.25 diameter bolts. The hub is a different design as is the rotor, and are not compatible between earlier hub and later rotor, and vise-versa.
Outer axle stub or fing birf-
Is going to be longer on the 1976 compared to the 60 series in the event that the stock axles are still in the 1976 front axle....again, no biggie, unless you are looking to use the 60 series outers for spares, in which case when you go to install one, you may need to grind the axle housing opening to allow the outer to slide into the housing. Also, with the longer outer, if you have the longer bodied Aisin lock outs, you will not be able to use them on the shorter outer axle stub with the snap ring that was originally installed on the outer axle stub, but rather, will need to use a larger washer and an 8mmx1.25 bolt to retain the axle outward into the lock out body....again, no big deal.
Good luck!
-Steve
Looks like I am going to have to do some mixing and matching between the axles.
I paid ALOT of money for thsoe OEM rotors...
grrr....
I want to use the FJ60 axle housing for the extra width, but I Was hoping to sell my FJ40 axles complete, minus the third members to try to recoup the costs involved...
