brake pads
Squamish
hey i was going to do a brake change on my 97 fzj80 and was wondering if i put 100 series pads if i have to mod anyhting or or they just bolt right on?
I've done it without problems on existing (i.e. non-new) rotors.
contact CDan or check the archives for the specific year 100 series pads.
Ditto.
As far as shaving.... thickness wise they "should" fit fine, although for some reason, some folks have had a problem with this, but most don't. Portions of the pad are slightly larger than the contact surface of the rotor. So after a while you'll end up with those portions pertruding as the wear surface wears down. I put mine in for a few thousand miles to define the unweared portions, then cut those out with a dremel cutting wheel, all the way down to the metal plates on the pads. Not sure it this is totally necessary, but I did anyhoo.
:beer:
Rookie2
cdan = CruiserDan = American Toyota which is a vendor in the Vendor section or at the top banner.
