brake pad change problem
In addition to checking your calipers as mentioned, it's sometimes possible for pads to fit poorly where they slide into the caliper housing such that they drag and need to be ground down some.
Make sure that the hardware holding the caliper is in good shape and able to slide on the mounting pins. Otherwise, I'd look to the caliber pistons. One or the other side is sticking. If this is the case, I'd buy a new or reman. caliper. Don't even mess around with rebuilding the old ones youslef. You life depends on working brake components.
bj42turbo said:
Thanks for the advise guys have taken everything on board and will look it to it on the weekend
BJ
have you tried it with your road tires back on :D
how about tire pressure?
