- Joined
- Dec 5, 2005
- Threads
- 2
- Messages
- 6
Heyo Folks,
Have a 92 FJ80. Had my master cylinder crap out on me, did the "Push and drop" test, pedal would drop slowly to the floor in about 15 seconds. I never had great braking, figured it was the master cylinder...
So purchased a reman, bled on the bench, installed and began bleeding my brakes.
Started at the passenger rear, then driver rear, then LSPV, I moved to the PS front, had an assistant pump the brakes, hold, and I cracked the bleeder, good flow.
Now the odd part, the second time my assistant went to pump it up he couldn't get any pressure, he'd pump and pump and it just wouldnt build up. I cracked the bleeder while he was holding it and barely a trickle came out.
So I figured I screwed something up and started in the rear again. Everything pumps up fine until I move to the front brakes...
Anyone ever encounter anything like this before? I've made a few calls to some other folks I know and no one has any clue, was hoping the pro's here could help.
Thanks much!
1992 FJ80, 216,000. Mostly stock... for now!
Thanks much!
